I have a pc-chips m\b m741lmrt and am trying to update the bios. cable modem driver is crashing and error says maybe update bios. system seems to be from co. called PROTAC in Australia. have seen their site and found file 010221s.rom. PC-CHIPS site has update file as 010914s.rom which do I use. Have checked AMI site and cannot ID m\b manufacturer using their utility. 62-1025-009999-00101111-071595-000000 this the id that comes up using amimbid.exe. The bios date on bootup says 10\25\1999S, protac site (protac.co.au)seems to have latest bios date.
Also I saw a post about hdd using pio mode only in winXP and fix was to slow down transfer rate to udma33 instead of 66 using program. can i ask did this work and my seagate st313021a is doing same. I went to seagate site and got uata100d.exe I guess this is similar prog , and how do i use it??
This a great forum , I am learning much from this site. keep up the good work!
Cheers to you all
