Hi
I seen to have a partially corrupt bios. I can access parts ok, but others are missing chunks. How can i aquire a replacement?
Its an Award 2A4IBR22 for an SiS 85C496/7 chipset.
Many thanks
Andy
NZ
Jamicon KM-S4-1 BIOS
Ah you have the Rectron variety of the board there. Do you think it is possible to email me a copy of that corrupt bios so I can try and match it with any of the unnamed bioses I have in here? I might have something that fits your board.
alter egos: KM-S4-1 ver:1.1
- also known as Jetway J-446, ATC/Unitron U6923, Azza 4SIG, Rectron RT-4s3 but no bios file yet, I'll keep searching.
http://motherboards.mbarron.net/models/ ... m-s4-1.htm
ouch:
http://www.jetway.com.tw/evisn/download/d446.htm
Can you check the part number of your bios chip please? You may need to replace the chip itself as well if it turns out to be an EPROM not flashROM.
EPROM
http://www.badflash.com/
or
http://www.flashbios.org/en/
required. I think what happened is someone tried to reflash the eprom with a flash program which basically killed it.
or
