I cannot find a bios flash for a board. Can anybody help?
The details are:
Exp8551 Ver 2.1
51-0000-001107-00111111-101094-INTEL-FX-F
Thanks in advance.
I need bios update - Exp8551 Ver 2.1
It's DataExpert EXP8551 board. Their site http://www.dataexpert.com.tw is currently down.
The latest AMI BIOS I could find for your board was:
http://212.76.48.153/DRIVERS/BIOSY/DATA ... 1AMI30.zip
51-0611-001107-00111111-071595-82430FX
EXP8551S Ver 3.0b <Plug n Play BIOS>
What I can't guarantee is if it's the correct release for your board.
garramantas
Thanks all.
But the problem that I have is the next.
When I connect the sound card, on having started the computer it goes out a message of keyboard fails and remains blocked. I have a contraladora scsi ISA and a card of video PCI in the computer.
garramantas
The sound card is old and the model is ESS ES1868 and I can not change the IRQ.
In this direction I have found the bios for Expert 8551
http://www.hktk.com/drive/drive_bios/da ... t8551.html
I am going to try to update the bios and already will tell you.
thanks.
thanks.
ESS1868-based cards are jumperless and Plug&Play compatible (I have one of them). However, there is a program than can be used to disable the PnP and set all parameters (like IRQs) manually. I remember running this card fine on a 286 computer
