help with bios
hello....i have an etower 700 that came with win me......have upgraded to xp. the mobo is an anaheim-3 with onboard video...got a new graphics card and want disable the onboard card....i reboot hit the del key and get a beep....no bios..I have tried f2 and other keys...no go....according e-machines you must hit the del key when the e-machines logo comes up....the only problem is that logo is no longer there since i did a clean install of xp.....how can i get into my bios....thanks in advance....kern
your machine is still working OK though?
You might try to keep a key pressed down while resetting generating a keyboard error from there you should be able to hit Del and Enter setup...
