I have upgraded the BIOS of my PC chips motherboard M572.
The old BIOS was 12/16/1997 S Release. The new BIOS is 02/24/1999 S Release.
Iam having the following problems
1) If I connect a 40GB Hard disk drive and give "Autodetect" the system hangs.
2) CDROM drive is not detected.
Note: With the old BIOS i was able to autodetect upto 8.4GB HDD and also CDROM drive.
3)If I donot give an autodetect 40GB HDD is recognised but sometimes CDROM drive is not recognised.
Kindly help.
Regards
Krishna Kumar
BIOS upgrade problem
Set the HDD parameters in BIOS manually and do not use autodetect.
