Hi there! I need to upgrade my bios, so i run the BIOS agent and i got all that info... but where can i download the upgrade?
its
BIOS TYPE: American Megatrends
BIOS DATE: 09/25/00
BIOS ID: 62-0925-000000-00101111-071595-V694V686-1V133001
where can i get the upgrade!?
many thanks all of you!
I need a BIOS update to an AMIBIOS
Looks like some type of Microstar MS-6309, but there are many. You need to open the box and look for the model and version number on the board. Some versions of 6309 were also called things like "694 Pro" or "694 Master". Versions go up to at least 5.0.
taumautaumau
ok! but where can i download the upgrade?
Please post your FULL Bios-ID and not only pats of it !!
Especially the section in the top left corner just below the AMI Logo is missing - should be something like A6309MS ......
also called Bios-Eval using the Bios-Agent or another program to identify a mainboard
From Microstar at the link I gave you above when you have identified the board.taumautaumau wrote:ok! but where can i download the upgrade?
