I have a ECS P6BAT-Me V2.0
and a Slot T and a Celeron 1400 Problem!
Al rund fine but a little Problem!
If i turn the Computer on it says Celeron 376
@ 2 x 188 MHZ
It runs @ 100FSB
On every start it says "i should set the Multi in Bios "
Press Del to Bios or F1 to continue!
Pressing F1 al runs fine!
The problem is i must always press F1 @ Start!
Can this be fixed??
Thank Gert
Update:
I have now patched my Bios with Biospatcher from www.rom.by
Now it says Intel Celeron (Tualatin) 14 x 100
Thats now correct!
But the issue with F1 and the Multi is still here!
Can it be changed that on Bootup all riuns normally??
Mongoo
