help i have a:
BIOS Date: 04/13/01
BIOS ID: 04/13/2001-i850-W83627-6A69SM49C
OEM Sign-On: W6339MS V1.3 041301 14:33:16
Chipset: Intel 2530 rev 2
Superio: Winbond 627F/HF rev 7 found at port 2Eh
OS: WinXP
CPU: Intel Pentium 4 processor 1400 Mhz MAX: 2000 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 512K
Memory Installed: 128 MB
Memory Maximum: 2048 MB
Memory Slot 01: 64 MB
Memory Slot 02: 64 MB
Memory Slot 03: 0 MB
Memory Slot 04: 0 MB
can some one help my to update my biso plz
help!updating BIOS
How To Upgrade BIOS:
1. Make a bootable system floppy disk.
(you can use this program http://www.abitfaq.it/Files/drdflash.exe to create a DR-DOS boot diskette)
2. Download the BIOS file from MSI web page.
You did this.
3. Extract the BIOS file into the bootable floppy.
Extract the files from the .ZIP to the bootable floppy.
4. Boot up system with the bootable floppy disk.
At this point the autoexec.bat should flash the BIOS with the command:
A:\AWFL789 w6339ims.140 /SN /PY /CC /R /LD
5. Run Award (Ex. Awdfl770) or AMI (Ex. amifl822.exe) Flash utility & follow the on-screen instructions.
This should happen automatically.
6. After flashing the BIOS, reboot system, press [DEL] to go into BIOS setup.
7. Select [Load Setup Default] for or [Load Optimized Defaults] and press Key [Enter] and
press Key [Y].
8. Press Key [F10] than answer [Y] to reboot system again and finish upgrade procedure.
Those look straight-forward; do you have a problem with any of them ?
You did this.
press Key [Y].
Is BIOS flash protection enabled in the CMOS ?
Do you have a manual ?
Here is the manual:
http://www.msi-computer.de/download/dok ... ng_pdf.zip
Check section 4, under Advanced BIOS Features there is a mention of BIOS Flash Write Control.
