Hi all
I just bought a HP Photosmart 7350 printer. When I plug the USB cable in to my computer, it crashes. It won't reboot properly when the USB cable is plugged in (gets past windows startup screen then flashes a blue screen with information written on it for a millisecond).
I believe this is a bios problem.
I have a lex BN870 ultra mainboard. I can't find any info anywhere regarding it. Their website is useless. CTbios, and info I've gleaned from reading these posts seems to suggest it is Jetway related.
Can anyone please help me A) Is this a bios problem, b) how can i flash it?
Program: eSupport.com BIOS Agent Version 3.31
BIOS Date: 07/06/01
BIOS Type: Award Modular BIOS v6.00PGN
BIOS ID: 07/06/2001-8363A-686B-6A6LMJ19C
OEM Sign-On: V.BN780_ULTRA B05 07-06-2001
Chipset: VIA 82C305 rev 3
Superio: VIA 686 rev 64 found at port 7h
OS: WinXP
CPU: AMD Athlon(tm) 1200 Mhz MAX: 500 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 1536 MB
Memory Maximum: 512 MB
Memory Slot 01: 512 MB
Memory Slot 02: 512 MB
Memory Slot 03: 512 MB
Memory Slot 04: 0 MB
CTbios adds following:
chipset: 8363A-686B VIA VT8363 KT-133
Pnp v1.0/ESCD DMI v2.2 SM v2.2
thank you all
Jim
Photosmart printer crashes computer
soupy
- Absentee administrator
Do all your other USB devices work properly? Does the printer work in the onboard USB port without the PCI card installed?
Try turning off the auto-reboot option so you can see what the BSOD says.
My other devices (cable modem, ipod) work fine. I'm just going to try uninstalling the card. How do i turn off the auto reboot? In bios?
E-mailed hp, they were less than useless
thanks again for all your help
soupy
Nope, in XP:
Right Click My Computer (System Properties)
Advanced
Startup and Recovery (Settings)
System Failure (uncheck automatically restart)
Funny now that I've thought about it, my BJC-6100 would BSOD on boot if I plugged into a *different* onboard USB port. Have you tried all the ports you have?
Advanced
soupy
Oh, I know. I just can't understand why anyone would want to use one. I guess some people don't know how to install a PCI card.-Jk- wrote:there are USB cable modems ya knowsoupy wrote:Oh, and just for future reference, your cable modem should be plugged into a NIC, not your USB port.
Soupy: Oh I know. I just can't understand why anyone would want to use one. I guess some people don't know how to install a PCI card.
Well since at least Pentium IIs it has been common to have the USB ports on the mb backplate. I think it is also starting to become common for LAN ports to also be mounted on that mb backplate, especially since more and more home users are setting up their own LANs.
But I guess then some people might not know how to setup a network hub, so that they can actually take advantage of what the LAN config offers.
I'd move the modem to the NIC as well, assuming it has an ethernet port...
I've heard of people printing while online and it crashes the USB modem port!!
Use the NIC for what it was designed for...networking!!
