Its p4 socket 478 with a via chipset
Kobian ( Mercury ) PVT800x-l Has any one got 1?
2 replies already thanks!!!
Ive already been too there website, (kobian)and(mercury)
no joy there and there support is Almost non existant.
The bios resorts to defaults every time i change them
before windows boots up (I flashed with pc chips varient of the same board i think they originaly made it)
thanks for the help guys any one have a pvt800x-l i can have a copy of the bios from? thankyou
I wonder if this reverting back to default CMOS settings every boot up is a common issue for PCChips boards. These boards cannot seem to retain your last saved CMOS settings, including Date & Time.
I've got 2 PCChips boards with this same problem (LM756 series) and the problem stays there even if CMOS battery is replaced with brand new one, even if the BIOS chip is replaced with known good one, or even if you flash the BIOS with other variant image files.
Can somebody please shed light on this issue?
Yes i think you are right!!!! i just found out the mercury board pvt800x-l is a rebadged pc-chips M952 PCB:V1.3b (I removed the pvt800x-l sticker from the motherboard and underneath was the proof lol)
so i flashed with the correct bios and its resorting too defaults any more ideas anyone is there a problem with pc chips bios updates or is it a corrupt flash?
It's not a corrupt flash if your PC is able to boot, but there seems to be an issue with these PCChips boards being unable to retain CMOS settings.
