hi!
is there a patched bios for an Tyan Trinity 100 AT (S1590S) board?
http://tyan.com/support/html/b_s1590.html
the latest official update is from 1/26/00 (V1.16c 092399)
which i have already installed, but it only supports hard disks up to 36gb.
can anybody give me a hint?
thanks
d.
Code: Select all
BIOS ID string: 09/23/1999-VP3-586B-W877-2A5LET5CC-00
BIOS OEM string: TYAN TRINITY 100 AT B1.16c 092399
Searching for size calculation routine...is already OK
Searching for SETUP size calculation routine...is already OK
BIOS already supports HDDs over 32GB & 64GB - Nothing to do!Tested patched BIOSes. Untested patched BIOSes.
No problem, 36GB is what it said on the website. The latest BIOS should support up to 137GB (128GiB).
