I require BIOS Update for PCI ver 2.2 o higher
is possible to load a new BIOS to do that ????
the problem is I have a Wireless board SMC 2802W that require PCI V.2.2 or higher.
you can help me???????????
thank,
vipa
my BIOS features are:
Program: eSupport.com BIOS Agent Version 3.43
BIOS Date: 05/09/00
BIOS ID: 05/09/2000-ALADDIN5-2A5KKB0DC
OEM Sign-On: ALC0509 FSC
Chipset: ALi M1541 rev 4
Superio: Unknown
OS: WinXP SP1
CPU: AMD-K6 500 Mhz MAX: 500 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 4 MB
Memory Maximum: 768 MB
Memory Slot 01: 0 MB
Memory Slot 02: 1 MB
Memory Slot 03: 0 MB
Memory Slot 04: 0 MB
Memory Slot 05: 1 MB
Memory Slot 06: 2 MB
update my BIOS for PCI ver 2.2 o higher
You have a OEM board Biostar M5ALC (2MB) for Fujitsu-Siemens.
Your motherboard has PCI 2.1 interface support only.
