i have PcChips M717 with PII 333 i'have flash it without problem with 1208.rom downloaded from http://www.pcchipsusa.com/support-disco ... iosnew.asp that passed OK , but after reboot the message is pentuim II 133 Cmos Cheksum bad Unlock keyboard
61-1208-007170-00101111-071595-m717-1440L000-H
m717 Mobo flash
i have found solution
1 st - you must have anOther good MOBO M7XX with amibios(Ex. i do it on M748MR)
2- verify you i/o chip for original MOBO for examp. iTE8671 OR 8679 you download bios for Adequate I/O chip from http://www.pcchipsusa.com/support-disco ... iosnew.asp
3 - do hot swap bios
4- and flash with amif818 what detect chips for flashing
it pass OK , take your bios and put it on your M717 , take fun with your M717
and your MoBO life again
