........"Looking for a BIOS update"!
Been looking for an update for my card.
Here´s what they told me. AMI that is.
An AMIBIOS ID String Was Detected:
62-0911-009999-00101111-071595-VIA_K7
| | | Chipset/BIOS Info
| | BIOS Build Date
| Manufacturer ID
BIOS ROM Information
AMIBIOS ROM Size: 256 KB
BIOS Build Date: Jul 15 1995
Motherboard Manufacturer Code: 9999 Not listed in MAN.DAT file
AMIBIOS Build Tag: 6ROM
AMIBIOS Project ID: 6ROM Not listed in TAG.DAT file
Any help would be great. Im currently suffering from the XP reboot syndrome after installing a new GFX card (Radeon 9550 ).
Hope to hear from you guys!
Cheers
Ted
Once again I´m stumbling into a forest called.....
62-0911-009999-00101111-071595-VIA_K7-6ROMTeddyF wrote:62-0911-009999-00101111-071595-VIA_K7
| | | Chipset/BIOS Info
| | BIOS Build Date
| Manufacturer ID
A6380MS V1.6 091101
Microstar MS-6380 - K7T266 Pro series.
Latest BIOS update:
http://www.msi.com.tw/program/support/b ... =27&kind=1
After a BIOS update is highly recommended that you reinstalls the OS.
Only if you run a crappy OS... Like Windows.KURIAKI wrote:After a BIOS update is highly recommended that you reinstalls the OS.
If you can't mod it, it's not worth owning.
