Hello everyone
I've managed to flash my GA-K8NS Pro board with a plain GA-K8NS Bios (F11), using the @BIOS program from Windows. I didn't intend to of course and I realise that a lot of readers will now be calling me a silly person or something like but Gigabyte's site showed the plain bios on their list of new updates and I just thought it was for both.
Anyway the system works absoletely fine without any issues, but I want to get the correct Bios in. @BIOS now refuses to accept the file for the Pro board and Qflash won't do it as the new bin file is larger than the active BIOS. I can't see Dual Flash - presumably as the system boots merrily.
I've Cleared CMOS by shorting the link but of course that just resets the active Bios default values.
Does anyone know what would happend if I boot to a floppy and use the Award flash program ? If it fails will Dual Bios then appear ?
I've subsequently downloaded the F10 package for the Pro board and it includes a flashing programme called Flash885. Does anyone know of this program ?
Cheers for any help
DT
GA-K8NS Pro with GA-K8NS Bios
Flash885 is an Amibios flash utility:
ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
³ Flash Utility Ver.885 ³
³ (C)Copyright 1985-2004, American Megatrends Inc. All Rights Reserved. ³
ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
Usage: Flash885 ROM_FILE /<COMMAND1> /<COMMAND2>...
A: Command Line Mode
B: Flash Boot Block
D: Load CMOS Defaults
E: Clear CMOS After Flashing
G: Keep DMI Data
R: Reboot After Flashing
S<File_name>: Save Flash ROM Data To File
-<Options>: Disable Flag. e.g. -A: Enable Window Mode, -G: Don't Keep DMI
B: Flash Boot Block
G: Keep DMI Data
