Can anyone tell me if there is a bios update available which allows the PCI/AGP Lock to be enabled or for the PCI/AGP Divider to work.
The FSB of the mobo will go up to 300 but it's no good as after 225 the AGP/PCI divider doesn't change, therefore putting the AGP/PCI bus way to high which is bad for the chipset/ GFX etc. I was wondering if there is a patch or abios update that will allow this
regards
Cowen1000
Asus K8V SE Deluxe (No PCI/AGP Lock)
Just wanted to say welcome to Wim's cowen!
There's no FSB on this board, only a system clock as a base frequency. Raising the system clock may lead to a too fast HyperTransport so lower the HT-Link multiplier in Bios from 4x to 3x. (Systemclock x HT multiplier = HT speed, this should not exceed 800 Mhz)
AGP/PCI should be locked on these new chipsets or is something different noted in your manual ?
I have lowered the HTT to 3 so that I don't exceed 800Mhz but the AGP/ PCI bus just keeps on going up where it should change when I hit 225. I test it using 'Clockgen'. I can overclock my system clock upto 290 when lowering my HTT to 3x but my AGP is @91 and my PCI is @ 48 which is way to fast (isn't) it. This is why i'm worried. I like overclocking as my old friend 'Kachiwachi' will tell you, so I would like to solve the AGP/PCI thing
@Kachiwachi
Hi old friend, 'long time no speak', it's been a long time since the days of my legendary journey of o/c'ing my K6 (Happy times they were) anyway I have moved on and have now built myself a SKT 754 Sempron 64 2800 on an ASUS K8V SE Deluxe. Don't think much of it at the moment. I'm only scoring 190 on CpuMark 99
My old Athlon XP 2800+ would score 225 so the performance of this new pc is poor in comparison. But if I can o/c it stable I should be hitting arond 250 points
Speeak to you soon my friend, I'm off to solve the riddle of my AGP/PCI thing.
@Kachiwachi
