• Quick links
    • Unanswered topics
    • Active topics
    • Search
  • FAQ
  • Login
  • Register
BIOS Updates forum
A forum to ask questions about bios updates, bios problems, bios settings and much more!
  • Home Board index Do you need a BIOS update? Other BIOS update issues.
  • Search
Ad blocker detected: Our website is made possible by displaying online advertisements to our visitors. Please consider supporting us by disabling your ad blocker on our website.
skip Extended memory test for PhoenixBIOS
  • Print view
Advanced search
1 post • Page 1 of 1
kocoman
BIOS Newbie
  • Quote
Fri Dec 16, 2005 4:02 am
I have a PhoenixBIOS 4.0 Release 6.0.C. Is there a setting that will disable the Extended memory test? I have 384mb and it takes so long 2 min to go through it. I can't press escape key to skip it.
Top
  • Print view
Return to “Other BIOS update issues.”
Jump to
  • Do you need a BIOS update?
  • ↳   My hard drive isn't recognized
  • ↳   My CPU isn't recognized
  • ↳   Video (VGA) and other BIOS/Firmware
  • ↳   Other BIOS update issues.
  • Do you have a BIOS problem?
  • ↳   My motherboard is dead
  • ↳   Power Management problems
  • ↳   RAM compatibility with BIOS
  • ↳   Notebook BIOS and other problems
  • Do you need information?
  • ↳   What is my motherboard?
  • ↳   Where can I find a motherboard manual?
  • ↳   What does this BIOS or Jumper setting do?
  • ↳   BIOS Utilities & Flash Programs
  • ↳   In-depth High-tech BIOS section
  • General
  • ↳   General BIOS Questions
  • ↳   Site suggestions
  • Read this before posting
  • ↳   The Rules.
  • ↳   Collected Wisdom
  • ↳   BIOS Services
  • ↳   How To
  • Home Board index
  • All times are UTC+02:00
  • Delete cookies
  • Privacy
  • Terms
Powered by phpBB™ • Design by PlanetStyles
Optimized by: phpBB SEO
