Hi again, I need an upgrade for other MoBo. It's a m770LMRT, I want to upgrade the processor, actually PII 400 Mhz to PIII 900. The PC is working just fine, but I need some extra speed. Increased the amount of RAM to 384 but still running slow. Appreciate the help
Greetings from Venezuela
Hidden
M770LMRT Bios Upgrade
if you have an i810 variant (rev 1.2) maximum is 600MHz, if you have an i810E variant (rev 1.2A) the limit seems to be 800MHz.
http://www.volny.cz/dzeman/mb/M770LMRT.htm
So no P3-900 for you I fear...
every S370 processor will work for you..the limit is the fsb. go for a celeron 600 and run it on 100MHz fsb (celeron 600@900). those coppermine celerons are really cheap and most of them work on 100MHz fsb without vcore change.
