I have an epox 8k9a3+ mobo with a hpt374 raid controller. The bios is out of date and the newer ones enable RAID 5. However because its embed the only way i can upgrade it is to flash with the motherboard's bios which has the raid controllers bios embeded. The motherboards bios is several versions behind and hasn't been updated in nearly 2 years (and likely isn't getting updated).
I tried combining the version 3.04 of the highpoint hpt374 bios into the epox k9a33a07 bios. I used CBROM 2.07 and flashed my motherboard several different ways (boot disk and awdflash, using epox's emergency bios update, etc. ) and each time the bios failed to work. It would restart and only display my graphics card info and hang. I had to use emergency bios procedures to get it back to normal.
I reset my cmos after each manual flash (using /cc in awdflash) and used proper flash procedures but it still wasn't successful.
I talked to highpoint tech support and they suggested I use a different CBROM, but I am unsure which to use. I don;t have a version 6 bios, so I figured 2.07 would be fine. I can;t find CBROM32 anywhere. If someone has it and would be kind of enough to give, it would be appreciated. You could PM me, ill reply with an e-mail you can send it to.
Some suggestions on what tools and procedure to use to mod my bios would be appreciated.
squeakyboy
Need to update my hpt374 bios on my epox 8k9a3+ motherboard
There are a newest BIOS update:squeakyboy wrote:I tried combining the version 3.04 of the highpoint hpt374 bios into the epox k9a33a07 bios.
http://www.epox.nl/downloads/bios/?obj_product_id=383
Cbrom 2.20
http://kuriaki.myftp.org:8245/Archives/ ... rom220.zip
Cbrom32 1.40
http://kuriaki.myftp.org:8245/Archives/ ... 32_140.zip
squeakyboy
thank you,
i was able to reflash using the original cbrom. I had failed to build the bios in the correct order the first time. i have now properly flashed my bios.
