Need Bios Update
it seems your mainboard is an oem version of the Asus A7N8X. you should check the oem site for an update before.
if you want to flash an asus bios to your board:
http://www.nforcershq.com/forum/a7n8x-b ... 15505.html
please take a look on the mainboard if you can find a hardware revision number somewhere (most probably in one of the corners) and pick the bios update accordingly.
A7N8X-VM uses AMI Bios in Retail version
A7N8X-XE uses AMI Bios in Retail version but it seems to be too recent to have a 2003 Bios
A7N8X-LA is an OEM-version for HP and uses AMI bios
These seem to be the only ones with AMI Bios in the A7N8X motherboard series, all others use Award Medaillon 6.00 Bios.
Did this board come out of a branded system (HP?) or is it still installed in such a system then contact the vendor and search their sites.
If not then open your case and look what's printed onto the board itself.
