GIGABYTE GA-6VXDC7 need advice
keeper5511
Hello! I have recently aquired a retro motherboard GIGABYTE GA-6VXDC7. Unfortunately when i power it led light works fine but i have no signal on the screen. I have tested ram modules and gpu but nothing happens. Motherboards switches and jumper for P3 CPU seems pretty easy from the manual but i have no success. Then i realize that bios chip was backwards and the primary socket of bios was a bit broken and i am not sure if this is the problem. Can i buy a new bios chip and try to install it on bios socket or is it better to install it on the second (2nd case)? Can i test the old bios chip or try to flash it? I am looking forward for your advise. Many thanks!!
