Hi everyone!!!
I need do flash correctly BIOS for MSI K7T266 Pro2 v.2.0 (6380) (VIA KT-266A), because when i tried to flash this chip with amiflash, after reset BIOS is flashed badly (Checksum Error / Bad). I've tried many times, but still it's the same. So my question is: Can I do hot swap this BIOS chip on MSI K7T Turbo Limited R (6330) (VIA KT-133A) or MSI KT4 Ultra (6590) (VIA KT-400)???
Thank you for yours replies.
CyberDe@th.
PS.
Sorry for my english, but i'm still learning.
MSI K7T266 Pro2 v.2.0 hot swap needed???
CyberDe@th
Links to texts about theese mobos are:
MSI K7T266 Pro2
http://www.msi.com.tw/program/products/ ... 0%20Ver2.0
http://www.msi.com.tw/program/products/ ... 0%20Ver3.0
MSI KT4 Ultra:
http://www.msi.com.tw/program/products/ ... EL=MS-6590
MSI K7T266 Pro2
MSI KT4 Ultra:
CMOS checksum error is normal after flashing
Just go into SETUP and save the settings.
CyberDe@th
I've tried to do this, but system cannot instal propertly.
If you can boot from floppy to flash, can you use Uniflash ?
CyberDe@th
No, I cannot use UniFlash, because the BIOS chip isn't recognised
But I change processor speed (A1700+) and I've installed system (Win98SE) without any problems. Then I've installed WinXP. After that I change processor speed to "normal" and system works stable. I think that, the processor is bad
