i have a FIC VL 601 -AMIBIOS- 61-1008-001121-00111111-071595-440LX-1440L000-H. I flashed a bios ( have done so a lot of times - always without trouble ! ) but now the PC wont start up anymore . No screen but the PC hears to work. How I will be able to arrange this?
thx
My Motherboard is dead after flashed...
Can You try the CTRL-Home key's , you must rename your old bios that you saved on disk to AMIBOOT.ROM or the new one.
thanks for the tip, but did not function, diskette gave error and lost the bios that had recorded. I tried to use 1 bios new with this name "AMIBOOT.ROM " in the filing-cabinet but it did not function... led of drive of diskette so lights to the beginning but it does not read... but of remaining portion it hears records to work... plus some ideia?
I there a jumper on the meanboard for recovery bois ! Then you can try the old of the new bios copy on the disk .
