i want to program my erased ami bios using another motherboard .
the problem that i haven t find identical mobo to do that .
my killed mobo is asus P4V533MX with bios chip PCM Pm49FL002T-33JC.
mobo i have found is asus P4XP-X with bios chip winbond W49V002FAP.
my question is that i can program wrong bios chp PCM Pm49FL002T-33JC
using mobo asus P4XP-X .
thanks all
program bios with motherboard
Thank you for your replay ,but i want to inform you that bios of the motherboard P4XP-X is from award fact and my bios motherboard P4V533MX is a ami bios.
so i can program my ami bios in the motherboadr P4XP-X
thanks
thanks
It may be easier to buy a new ready flashed BIOS chip ready to plug in from here
http://www.badflash.com/
Cheers HC
Cheers HC
zonxar
- Master Flasher
Perhaps a read through these might help:
http://www.wimsbios.com/phpBB2/viewtopic.php?t=6481&
http://www.rainbow-software.org/hardware/hotflash.html
http://www.rojakpot.com/default.aspx?lo ... =62&var2=1
