Winsonic
my friend gave me his winsonic wsv0a09 s370 atx mobo. He said its dead for failed flash update. Anylinks for its correct bios file to download. Pls help
Motherboard saved!
I can't find that model anywhere. Are you sure it is not:
WSV9a09?
Image link if it doesn't show above.
WSV9a09?
Some problems with performance and availabillity at archive.org at present... thanks for the picture, Kuriaki
That is just the winsonic section that has troubles. From the looks of the only bios available it seems they were relabeling PcPartner boards.
@Noel: check the upper left corner as shown in picture for a 35-xxxx-xx marking in very fine print, it may be in white ink or etched in the board material.
Im sorry for late reply. I gave the board back.
Motherboard saved!
