Plz give me help.
I have a 6abx2v verison1.2 with a Award Modular bios v4.51PG from Lucky Star.
I have killed it.
I used Uniflash 1.27 to flash it again.
The help file says create a emergency disk.I have create a disk.
But the help file even says i must have a isa grafikcard i buyed it .
Then i do what they say.But here is the problem the computer dont read from the disk what should i do.
Please Please Give Me HELP
I have found in the case of Award BIOS on PC-Chips M577 that an ISA floppy controller worked. I think it will be easier for you to "hot-swap" the BIOS chip into another board and flash it there, if you can find a board which takes your size and voltage of chip.
