Ho kay , if were all stitting comfortablyi shall begin :
I'm running a small network , for my own fun , and i add terminal as often as i can. My new'est one is a M-520 mother board and thats it. I have enuff parts riped from terminal that died on me to make a new one. SO this is what i have added to " try " and get her up and running
BIOS:
AWARD PCI/PNP 586
S/N 05065283 V
Processor:
IBM 6x86 P166+
(IMB26 6x82-2v7P166GE)
( 133MHz/3.5v )
However , when i give her some power , she just sits there. Hard Drive light stays on and PC spk just beep on , off , on off. Does any one know what is wrong?? Me thinks its one of two things
ONE :
Shes does like the Prosessor so wont work for me.
or
TWO:
The BIOS / CMOS or jumper setting are screwd.
..........help??
My M520 is dead and I'm so very witty...
Reseat the memory.
Reseat=take out, put back in carefully ensuring it is pressed fully into place.
Disconnect all drives and see if that helps.
