I have a V266B jetway motherboard. After flashing my bios incorrectly, my computer now says:
Award Bootblock v1.0
BIOS ROM checksum error
INSERT SYSTEM DISK AND PRESS ENTER
Basically, i can only boot into the dos prompt from a floppy. I've tried re-flashing with awdflash and (what i think is) my latest bios driver, V266BA10.bin from the jetway site, www.jetway.com.tw
That doesn't work! I still get the same error message. I've tried leaving my motherboard battery out all night but that makes no difference either. What can I do? Should I use a different flash program?
BIOS write-protected - Rainbow help
Yes. I tried using uniflash aswell but that doesn't work. Apparently my bios is write protected, but I can't change that in the bios because I can't get into it. I can't find anywhere on my motherboard a jumper or anything that I can disable write protect. I also can't remove my flash rom chip.
