Hello there!
I flashed a Soltek SL-75KV+ to version Q10 with the program awdflash, which was in the zipfile
with the updatefile!
I restarted my computer a couple of times and it worked!
But when I (shuted)? off the Computer,I couldn´t start it again. It ran only one second and cheep
one long time and then it shut(ed)? down!
I tried to reflash the Bios with another Computer (I changed the Bios chip immediate before i pressed Enter to flash) but there was the message: The Bios number
doesn´t match with your system
If someone help me,i will be very grateful
Cu, Don P.
Soltek SL-75KV+
Maybe CPU overheat protection is enabled? If it doesn't get the tach signal from the CPU fan, it will beep and power off the system immediately.Don Promillo wrote: I restarted my computer a couple of times and it worked!
Don Promillo
- BIOS Newbie
I tried both possibilities!
There are no differences, just beep and shut down...
Don P.
Don P.
Don Promillo
- BIOS Newbie
I´m sorry!
The Fan has 2 cables, a red one and a blue one!
I´ve just tried another one,which has 3 cables (red,blue,black)
If it had been the problem with the CPU overheat protection,it would have been worked for me, normaly?
Don Promillo
- BIOS Newbie
The board is already alright!
Thx Don P.
Thx Don P.
