Hi:
My english sucks, sorry, but i gonna try to explain my problem
i have a pc chips M963G(the version, isn't print on motherboard, but i guess is 3.1 (on back cover of manual apear 3.1 version).
i had the problem that the hardisk and CD rom (both on primary IDE, master and slave) only recongiced when i reset the pc. i solve this, the trouble was the ultradma ide cable, was connected on wrong way.
But after to solve the previus problem, i upgrade the bios flash. with 040510S.rom using amiinf340.exe to do that(both files downloaded from pchip site).
And now, the PC dont start, only if i move jumper to reset CMOS memory start, but when i reset or start again nothing happends, no video, no beeps, nothing.
then i think battery problem, i tried with another, an nothing happend.
so i think is a problem with the version of bios, but i couldn`t find the previus version on pcchips site. Someone have this rom file???, or someone knows how to solve my problem???
please help.
thanks
Unable to start the PC (PCchip963g) i need the original rom
Pcchips lists Rev 1.3 and Rev 3.2 on it's website - you have to look at your board maybe near the keyboard connector to find your revision number .
Manual revision and motherboard revision are two completely different things !
