I have just acquired an AMD Athlon 1000Mhz mobo n chip, taken out of a tiny base unit, motherboard is an MS-6191 made by Microstar Intl. I flashed the bios up to rv 1.6 using the update from msi's website, and flash goes well but comes up with 'flash programming error' at the end, i thought ok and reflashed, same thing happens. i rebooted to see if it would run (been here before with an old pcchips M575, so i knew about the bios recovery) and it boots fine, but fails during hardware detection in windows xp setup
thanks in advance AJ
