hi,
my ax63 motherboard's bios is very problematic. it's experiencing "checksum error" , and i was not able to boot from floppy drive.
i read the FAQ's section and i saw that i can use an ISA multi I/O card to boot the floppy..
but i think there's a conflict with the built in fdc and the ISA Cards FDC.
what can i do????
please help
God Bless
AOpen AX63 Bios problem
notinthisworld
- BIOS Rookie
Last edited by notinthisworld on Tue Jul 18, 2006 2:46 pm, edited 1 time in total.
notinthisworld
- BIOS Rookie
hello, thanks for the reply, the ram passed my memtest++, the battery is new.
same result, still bios checksum error.
thnx
God Bless
thnx
God Bless
Question unanswered:
Bios ROM Checksum Error or CMOS Checksum Error ?
Please specify the full error message, if it's a Bios ROM Checksum error your system should not boot but ask for a floppy to reflash or similar. If your Bios is working just normal but you get a Buios checksum error if it tries to boot it may also be a Virus/infection.
A Bios ROM Checksum error may not only be cause by memory, it may also the CPU (damaged Cache) or the motherboard (leaking capacitors, damaged memory controller)
notinthisworld
- BIOS Rookie
hi,
it's Bios ROM Checksum Error. yes it asked for a floppy , but when i inserted a bootable floppy, it will read for just a second or two, but it wont continue to give me a command prompt. it's stuck.
then i followed the wimbios' FAQ # 27, "use a ISA multi IO card", still no luck coz i think it's experiencing conflict with the Motherboard's FDC.
please advice.. thanks
God Bless
God Bless
notinthisworld
- BIOS Rookie
hi guys,
it's now fix! thanks a lot, i just hot flashed it and now its working.
God Bless
God Bless
