This is my first post here, so a big hello to all
I have a HMwent thin client industrial PC with a Boser HS-4500 motherboard. The manufacturer flashed the BIOS so that it boots only from the network card. It does not boot from the floppy or the HDD. BIOS has etherboot on it.
How to solve this problem?
Can I do it myself or I require an EEPROM flasher? Maybe if we flash the EEPROM with the original Boser's bin, it will come back to normal
If someone can help me I'd be really grateful. Nice website, by the way ! Thanks for keeping it up!
Regards,
Rajiv
More info:
The PC is this one:
http://www.hmwent.com/ic_details.asp?se ... in+Clients
Motherboard info:
http://www.boser.net.cn/products/sbc/hs4500.htm
and the manual is here:
http://www.boser.com.tw/manual/HS-4500v2.3.pdf
I can see the BIOS .bin file here but the download link does not work:
http://www.supportbios.info/modelo.asp? ... &Idioma=EN
