I am troubleshooting a board for a friend.
MSI K7 Pro + AMD K7-600MHz Slot 'A'
What happens is the board boots, then mysteriously shuts off. seems to stay on shorter periods of time if I restart it within a short period of time.
I have checked all heat issues...everything fine.
CPU is Fine
RAM is fine
Video is fine
PSU fine
...all checked seperately in other boards. I dont have another slot a cpu to test on the board though.
I am only using video/cpu/Ram to boot up
I have no idea what else to try...I even checked for cold-solder joints...nothing
any input would be greatly appreciated
thanks
K7 Pro boot probs
Usual aspact is PSU and FAN .
The Athlon 600 Slot-A needs a huge amount of powhlon especially on boot-up - maybe the PSU does not have enough power anymore .
Or your CPU-Fan is not working OK so Fan-monitoring shut down your system
