Hallo,
On a Mb Hot 591P ae 4 banks to plug in ram mem.
Or 2 modules Sim or 2 modules of Dimm can be pluged in.
Is there a way to use al 4 banks at the same time and use more mem this way?
Tkx,
Maanse
HOT 591P MB question
http://de.shuttle.com/591p.htm
3 memory banks - the two SIMM are one bank
Either use SDRAM or EDO but not both types and EDO does only work up to 66MHz
Try to get bigger SDRAM sticks if you need more memory - ask for i440BX compatible sticks as they should for fine in VIA MVP3 chipset
Feel sorry but i was hoping for the other answer.
Tkx anyway now i know i should find more mem on a stick.
Maanse
Also loking for the latest bios firmware.
Not so easy to find, all the links seems to be dead.
Any kind of help here?
Tkx again
Maanse
Tkx again
