i've got a compaq presario 700 laptop with
128mb onboard memory (some models come with 256, not mine)
1ghz amd mobile duron
20GB hard drive
it lags while loading stuff example: internet explorer, msn, startup, ...
I found a 64mb ram thing it fits nicely in the mini ram slot (i dunno how its called on laptops) it boots into XP but still tells me that ive got 112MB ram(the onboard VGA uses 16mb) i know 64mb is not much but im sure it would load just a bit faster.
and if i remove the ram nothing happens (the system continues to run) so i guess it's the crappy Compaq bios that's the problem.
help !
Compaq Presario 700 laptop memory undetected
Nope. Could also be the hardware that does not like it. It may even be the memory stick that has gone kaputt. What is the brand/model of that memory stick?
yep, or ECC where this one does not want it or maybe even (although very rare these days) a requirement of some Compaq tattoo in its chips.
http://www.crucial.com might do the trick.
