OK...
So then if you boot to DOS (mode), what Mode is the drive in, assuming it is set in the BIOS to UDMA?
How can the drive force a Mode on a BIOS that it doesn't know about? The drive doesn't "send data" to the BIOS/Chipset...it just reports what it is capable of and then the BIOS does the setup...right? If it can't do UDMA5, wouldn't it just go up to UDMA2 and set that...assuming it is intelligent enough not to mis-interpret things and set it up for PIO-1...LOL
If the drive is only MWDMA1 capable, what does setting Windows DMA do?
I have 2 utilities that I use...ATAPROBE and ATAINF...that run out of DOS to see what Mode my drives are in. With the Seagate, it is too new a drive, and the results are not entirely accurate (the programs are 1996 era). But I do have a drive that posts a result not what it is capable of...I'll put the result printout here when I get home...thought it was SWDMA2...but in any case...enabling DMA on that drive would make it run slower than in PIO-3...correct??
Back to the UDMA33 bug...is it all UDMA modes or just UDMA33? Can UDMA0 (16.7 MB/s) and UDMA1 (25.0 MB/s) still be set, if I had a drive that utilized it (from what I have read, only UDMA2 (33.3 MB/s was ever implemented in a drive...)?
