Its a MicroAtx board, PGA 370 Socket, Via VT82C693/VT82C596B bridges. ESS solo-1, ITE it8671F, ITE IT8687R. 2memory slots No identification on board but S/N: M9912082120 printed on ISA slot. Someone has put away the bios chip, but label is: Award @1998 PCI/PNP 686 206829289. Also printed on board is text "Year 2000 Compliant"
Any help to identyfy it is most appreciated1
Help to identify this motherboard
Please post the entire bios string (if available), the form factor (AT, ATX, NLX, LPX), power connector type (single row and/or double row), the processor/layout specs of your board + any names/numbers you find on the top surface of the motherboard. If this is a branded system, post make and model.
Form Factor i microATX, Bios tring not aviable since the Bios is Dead, Power connector i standard double row. Thera are no more names/numbers on the board
1 ISA, 3PCI, 1 AGP
1 ISA, 3PCI, 1 AGP
Yes!
It looks very similar, only some components missing on my board and different colours on the adators in the back, mayby only different PCB
versions I guess.
Thanx for your help!
versions I guess.
