WHO KNOW THIS BOARD?
I CANNOT FIND ANY MARK OR MESSAGE ON THIS BOARD。
09/07/2001-i815-W83627HF-6A69RTRDC-00
Mentioned here:
http://it.sohu.com/webcourse/expert/200 ... 10035.html
babel translates a suspect manufacturer as "side dimension" from Chinese.
TopStar board with i815 chipset - they all have same BIOS ID, OEM ID is diiferent, this is from TM-815E:
TM-815E VER:1.4 (2001.09.13)
http://www.topstar1.com/html/driver_mb1.htm
BTW.: We can add new manufacturer code.
Weird: I have some Totem BIOSes that look like PC Chips boards (810LM11.BIN - M770 inside, 1631V31.BIN = M754LMR)
The other plausible story would be Topstar has always made the boards for Totem and Totem has switched to PC Chips, thereby forcing Topstar to do their own retail bussiness from now on.
If you look at the Totem product line it stops where the Topstar product line begins. Exactly there.
Exactly.edwin wrote:If you look at the Totem product line it stops where the Topstar product line begins. Exactly there.
Another thing. Topstar has BIOSes for some ZIDA boards one Epox (TM-686ZX) and one Jamicon/Kaimei on its page. http://www.topstar1.com/html/driver_mb3.htm
