Greetings,
I would appreciate if anyone has the BIOS update for the followings:
BIOS ID : 11/11/1999-693-596A-CD-2A6LGD4FC-00
BIOS Date : 11/11/99
BIOS OEM Signon :
BIOS ROM Size : 256K
Chipset : VIA 82C691 rev 68
Super I/O Chip : Winbond 83977EF found at port 3F0h
Thanks.
Looks like DFI PA61
http://sj.dfi.com.tw/product/fetch.asp?theValue=PA61
http://sj.dfi.com.tw/support1/download2.asp
kindred
Greetings,
I tried to flash the BIOS. But after which, The Windows just hangs on the desktop during loading. I did set to load optimal in setup BIOS, but the result is still the same.
What's the problem?
What's the problem?
The Truth Is Out There...
soupy
- Absentee administrator
http://www.wimsbios.com/phpBB2/viewtopi ... ght=#16787
http://www.wimsbios.com/phpBB2/viewtopi ... ght=#16782
Let's keep it to one thread per motherboard, please.
