houston technologies....M7171-S8-AT
give me some info or available bios updates or a website for this board?
houston technologies - M7171-S8-AT
hehe. You'd reckon they only relabel the PC Chips boards that actually have one of those BS thingies on them then?
thanks so much for the info.....
another question... atx form factor card...i dont have one..do i really need to purchase the card for using the usb, ps2 mouse and ird ?
if the pins are known can i just put plug on pins and wire it correctly for all the devices? usb mouse .etc
My ATX form card also has some R/C decoupling to prevent RF emission by the look of it, plus the odd inductor and power smoothing cap, but nothing fancy. In principle you should be able to build your own cables.
connector ...done....successful
pins for mouse and usb ...a little orientation of the pins was tricky with the diagrams and running usb camera
tested...works great !!!!
thanks to everyone who replied !!!!!!
