I have a client with a motherboard with the BIOS string 2A69KPWBC-OO.
This ID code PW does not appear to be listed on the AWARD BIOS NUMBERS page ie PW is not there. This client would like to install a large capacity H.D.D. but without a flash utility this is not possible. Can anyone help?
I need help ID-ing this Motherboard
The vendor is Protac, according to a Google search on "2A69KPWBC". However, this turns up multiple possibilities:
? i440ZX-2A69KPWBC
or (highest probability)
MX320/322 - 03/15/1999-i440ZX-W977EF-2A69KPWBC-00
If it's MX320/322 then it's already been patched - see http://wims.rainbow-software.org
? i440ZX-2A69KPWBC
This seems to be VERY weird board. Do you have a photo/scan or another picture?
http://web.archive.org/web/200002011536 ... mx320s.htm
http://web.archive.org/web/200003030905 ... om/toc.htm
and a load of robots.txt fies...
Also:
http://web.archive.org/web/200007110244 ... com/mb.htm
http://www.soundcard-drivers.com/companies/858.htm
http://www.storagedrivers.com/companies/858.htm
MX320S is the name. Chaintech has bought Protac and killed off the motherboard section instantly... Rumour has it this is a M761ZX
http://www.pcwave.com/prod761zx.html
