I have a Slot1 MB ATX no video or sound on board. I need to ID the only markings on the board is TMP2VAP v3.1
any ideas.. thanks in advance
Slot 1 Motherboard ID
linux_power
yes it has also it has a 2 digit LED display on the motherboard for post errors.. currently the motherboard will not boot up and displays a 2 digit POST error - need the manual in order to find out the problem.
Hah! I bet your all-seeing eye didn't spot that LED display, Soupy!linux_power wrote:yes it has also it has a 2 digit LED display on the motherboard for post errors.. currently the motherboard will not boot up and displays a 2 digit POST error - need the manual in order to find out the problem.
linux_power: For post codes, look at http://www.unicore.com/techsupport/award/postcodes.htm
If you know from the label whether the BIOS is Award, AMI, etc, this may help.
You could also email [email protected] as he is looking for your BIOS - see http://www.driversearch.com/forums/bios/1489.html - as long as you can find a common language. Unless selo is you, of course.
@Soupy: Did I remove the link to that driverforum posting in my post or did you ?
I think my new title could be "Semi-senile". I certainly don't feel like a guru when Rainbow or Edwin points out my stupid mistakes...
Just corrected the corrupt files here:
http://www.elhvb.com/mboards/totem/manuals/
It's available now.
It's available now.
