hi together,
i need help to identify my mainboard.
it has an amd-751 chipset and the bios id is shown above.
i think it´s an oem mainboard, but i don´t know exactly.
hope you can help me out to find the manufactor of this board.
thx
here are some more informations about the board (by sisoft sandra)
SiSoftware Sandra
General Information
Manufacturer : American Megatrends
Date : 12/23/99
Plug & Play Version : 1.00
ID No. : FC 01 00
System Mainboard
Manufacturer : OEM BIOS
MP Support : No
BIOS ID : 62-0720-000000-00101111-071595-A751V686
System Chipset
Model : Advanced Micro Devices (AMD) AMD-751 (Irongate) CPU to PCI Bridge
Bus(es) : ISA PCI
Max FSB Speed / Max Memory Speed : 2x 100MHz / 1x 100MHz
In Order Queue Depth : 8 req(s)
Logical/Chipset Memory Banks
Bank 0 Setting : 64MB SDRAM 6-1-1-1R 5-1-1-1W 2-2-2CL
Bank 2 Setting : 128MB SDRAM 6-1-1-1R 5-1-1-1W 2-2-2CL
Bank 4 Setting : 128MB SDRAM 6-1-1-1R 5-1-1-1W 2-2-2CL
Multiplier : 1/1x
Power Down Mode : No
Fixed Hole Present : No
and by the ami identification tool:
AMIBIOS Motherboard Manufacturer Identification
Version 1.2 (02/07/2001) Copyright 2000 American Megatrends, Inc.
This file has recorded information useful in identifying the manufacturer
of this motherboard. The information is listed below:
An AMIBIOS ID String Was Detected:
| | | Chipset/BIOS Info
| | Manufacturer ID
| Version Information
Processor & BIOS ROM Information
The Manufacturer Code Detected (0000) Does Not Have A Database Entry.
The Following AMIBIOS Project Tag Was Found: _TG_1EVT300
62-0720-000000-00101111-071595-a751v686
Looks like FIC SD11.
http://www.fic.com.tw/support/motherboa ... model_id=9
