Hello all,
I ran some BIOS utilities to find out the manufacturer of my board. I found out that it is an ECS board (FCC id 1131). The BIOS string is:
62-0926-001131-00101111-071595-SiS730S-M810LR7-H
I don't know the model number, though. The ECS site says that it should be next to the AGP slot. I've been looking for a while and I can't find a damn model number. I have a feeling it is a K7SEM, but I don't know what revision number.
The board is made of red material. It doesn't look like an FR4 to me. Somewhere on the bottom it says something like: REV 71C
Also: I'm looking for a way to disable the on-board video. It's sharing 8mb of memory and I want to use my PCI card instead. There's no option in the BIOS, though. Hopefully, if I can find the model number, the BIOS update will have it.
Thanks!
ECS board, but can't find the model number
Try PC-Chips M810LR Rev 7.
ECS/PC-Chips/Hsing Tech are related.
Update:
PC-Chips M810L V7.1C
At ftp://ftp.pcchips.com.tw/bios/M810lv71c/ there is a BIOS 020926s which is probably your present BIOS. There is a later one.
Update:
http://www.pcchips.com.tw/product/M810Lv71c.html
Board with Hardwired Duron 800/850/900MHz but calling him Pro 1200+ or something like that
Good source of Information :
http://radel.inet.net.nz/m810lmr.html
