Need bios and/or internet site for MAAV363BC
Hi. It should be an EXTREME mb, but I think there's an identical model from Jama and Gigatech, but I can't find the internet site of the EXTREME and a bios from any of them. My version is dated 2000, I know there are newer ones. XP is hanging randomly and I think it's an ACPI trouble...thanks!
If that's an ATHLON board, then I'd compare it with the ECS K7VZM.
An archive.org search for www.jama.com.tw proved that most of the pictures (gone) for the AV363B board were in a /K7VZM/ directory.
http://www.jama.com.cn/jama/drivers/bios/index.htm
But it's Chinese
Maybe translation is better http://babelfish.altavista.com/urltrurl ... &doit=done
But it's Chinese
I tried...downloaded the last version (march 2001) and tried to program, but the awdflash says that my chip's part number is different from that one in the new bios...can I try the same? If something goes wrong, is there any procedure that can help me putting back the old bios?
If it says that BIOS ID is different, don't flash. Send your curent BIOS ID (complete!)
That warning message is quite normal, because the new bios string is:
03/13/2001-8363-686B-MA-AV363C-00
(note the change from 686 to 686B).
The jama.com.cn site mentions 686B for both the 1.1h and 3.2 versions.
