Hi all!
Anyone able to tell me which motherboard this is please? The MB disk that came with it with all the drivers on it appears to be for some other motherboard.
Thanks for any help!!
10/25/2002-1845GE-6A69XG06C-00
If you type in www.wimsbios.com and look at the top of the screen, there should be a small graphic with "BIOS Agent, Makes it Easy". If you click on that it takes you to a download site that has a program that lists many system/BIOS related output that is useful in identifying boards.Flasher wrote:I dont know what you mean.
I posted the motherboard details which usually identify a motherboard but I cant see any way of identifying it here. I was just asking if someone could identify it for me, please.
This is explained in the posting guidelines for this specific forum
http://www.wimsbios.com/phpBB2/viewtopic.php?t=1249
That program said this:
Program: eSupport.com BIOS Agent Version 3.23
BIOS Date: 10/25/02
BIOS ID: 10/25/2002-I845GE-6A69XG06C
OEM Sign-On: Intel 845GE AGPSet BIOS for 8GEMT4 F2
Chipset: Intel 2560 rev 3
Superio: ITE 8712F rev 5 found at port 2Eh
OS: WinXP
CPU: Intel Celeron(R) 1700 Mhz MAX: 3066 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 256 MB
Memory Maximum: 2048 MB
Memory Slot 01: 256 MB
Memory Slot 02: 0 MB
eSupport.com, Inc.
1-800-800-BIOS (2467)
www.esupport.com
BIOS Date: 10/25/02
OS: WinXP
BIOS ROM Size: 256K
eSupport.com, Inc.
www.esupport.com
