PII Mobo: 12/18/1998-i440LX-W83977-2A69JPAAC-00
1. Is there a BIOS OEM message under the Award logo on the memory count screen ?
2. Anything printed on the board ?
zonxar
- Master Flasher
Here is the EP-61LXA-M to compare with your board:
Specifications, etc. here:
http://www.epox.com/USA/product.asp?ID=EP-61LXA-M
zonxar
- Master Flasher
Hi K4
Are you saying that your board has nothing to do with the original post, but that you need help to ID?
If so, I would suggest starting a "new topic" so that responses don't get mixed up, since these are different motherboards.
Also, tell us how many PCI, ISA slots, dimms, what type of processor slot/socket etc. your board has, and is that the complete signon string?
KP6-LA perhaps.K4 wrote:Hey,
Unfortunately the photo above has nothing in common with my mobo.
(My proc & RAM slots are horizontal, etc.)
My BIOS OEM sign is:
12/17/1998 For i440LX/EX AGPset
Thx.
http://www.embeddedlogic.com/TH99/m/E-H/35234.htm
According to Wim's BIOS BIOS Numbers section, your ID string matches the following models:
2A69JPAAC (The ID string you posted).
Epox EP-61EXA-A
or EP-61LXA
or EP-61LXA-M
or EP-LXR
or KP6-LA
If this ID string is correct for your board, one of those models should be your board.
All the ones I could find manuals for displayed CPU and RAM slots running at right angles to the PCI, AGP and ISA slots.
I could not get up an english version of the 2TheMax website.
Maybe you could photograph your board and post the photo.
Epox EP-61EXA-A
or EP-61LXA
or EP-61LXA-M
or EP-LXR
or KP6-LA
It does fit. EP-LXR is most probably the same board as EP-68LXR.K4 wrote:Case closed, the board reads EP-68LXR.
So why doesn't the BIOS ID fit?
