award modular ios v6.00pg upgrade
OK, but we need your information prior to help you.mojo wrote:I will reply with more info if someone can help me.
A good start can be running BIOS Agent, saving report and posting it back:
http://www.unicore.com/biosagent/index.cfm
here's what i have
Program: eSupport.com BIOS Agent Version 3.42
BIOS Date: 08/10/01
BIOS ID: 08/10/2001-VT8366-8233-6A6LVAB9C
OEM Sign-On: AK77Pro R1.01 Aug.10.2001 AOpen Inc.
Chipset: VIA 82C3099 rev 0
Superio: Winbond 697HF rev 6 found at port 2Eh
OS: WinXP SP2
CPU: AMD Athlon(tm) 1000 Mhz MAX: 1500 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 768 MB
Memory Maximum: 1024 MB
Memory Slot 01: 256 MB
Memory Slot 02: 256 MB
Memory Slot 03: 256 MB
Memory Slot 04: 0 MB
eSupport.com, Inc.
1-800-800-BIOS (2467)
www.esupport.com
BIOS Date: 08/10/01
OS: WinXP SP2
BIOS ROM Size: 256K
eSupport.com, Inc.
www.esupport.com
zonxar
- Master Flasher
Appears to be an AOPEN AK77 Pro motherboard - support page is here:
http://global.aopen.com.tw/Products/mb/AK77Pro.htm
The BIOS download can be accessed from the column on the left, but a word of caution - there are several versions of this motherboard, so make sure this is the match for your motherboard.
Ok thanks for reply.. i just thought that an update would really speed it up or something ..what happens when a bios is updated or flashed does the comp run alot quicker?If the changes are minimal then ill hold off cause i have a 1000mhz and it runs good but more speed would be nice.Sorry if these questions sound ridiculous cause i am a bios newbie!!BTW you are correct i did a visual and it says ak77 and the one shown at the link you sent is identical but still dont understand what exactly to download?? i see bios on the left but theres 10 diff files like 1551-AW1/AG1 and 1551-OG, s661FXm--S and others so im confused on exactly what file to get if i decide to update?
zonxar
- Master Flasher
I think what you did was click on the BIOS link twice. The first click should have brought up a page listing 11 downloads for the AK77 Pro, with R1.20 dated 2/19/2003 listed at the top.
KURIAKI has posted the link for R1.20 in your other post, but unless you plan to upgrade your processor I don't see any gains for you. If you choose to go ahead, read what is available on this site regarding updating the BIOS and as well, I believe there is information on the AOpen site that explains the process to follow.
