Hi any help would be greatly appreciated, this is the BIOSinfo for my machine at home, which is not web enabled, thus I'm finding it difficult to find the correct information pertaining to my system. I want to upgrade the BIOS.
BIOS Date: 10/25/02
BIOS ID: 62-2002-001199-00101111-040201-KM266A-GA7VKML1
OEM Sign-On: 7VKML F6
Chipset: VIA 82C3116 rev 0
Superio: ITE 8705/SiS 950 rev 2 found at port 2Eh
OS: WinXP
CPU: AMD Athlon(tm) XP 2000+ 1667 Mhz MAX: 2133 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 768 MB
Memory Maximum: 2048 MB
Memory Slot 01: 512 MB
Memory Slot 02: 256 MB
eSupport.com, Inc.
1-800-800-BIOS (2467)
www.esupport.com
Thank you in advance
Jason Black
